I've tried Sleeping Dogs and The Saboteur. Both of them are on GOG.
Sleeping Dogs, when in-vehicle, RT should accelerate your vehicle. It does nothing. Pressing LT honks my horn (which is actually supposed to be right-stick click). On-foot LT/RT does nothing.
In The Saboteur, RT doesn't do anything.
So, I exited out of Rewasd, and opened Steam. Loaded up Fallout 4 and RT functions as normal.
I just tried "clear data" in Rewasd and applied the 360 config. It didn't fix the problem.
(Note: Steam isn't open when I'm using Rewasd.)
Single Press] activator.
