[HELP!] LT/RT+Full Pull, L/R Pad Clicks...maps of Steam Controller are all messed up!
This topic has been answered.
  • [HELP!] LT/RT+Full Pull, L/R Pad Clicks...maps of Steam Controller are all messed up!
    [EDIT:] Solved!!!
    After the 6.1 update, every game I run, all my Steam Controller mapping profiles for the Left/Right Trigger + Full Pull, Left/Right Pad Click and Left Back button are all broken!
    No matter what input I remap to these axes and buttons, they are all the same in the output respectively:
    ● Left Trigger always becomes -> Left Shoulder button
    ● Left Trigger Full Pull -> No output(Can't be remapped to anything!!)
    ● Right Trigger -> No output(Can't be remapped to anything!!)
    ● Right Trigger Full Pull -> B button
    ● Left Pad Click -> Xbox button
    ● Right Pad Click -> No output(Can't be remapped to anything!!)
    ● Left Back button -> A button
    This is driving me nuts!!!! Please help ASAP!
  • Answer selected by reWASDer at 02.03.2022, 18:56.
    Originally Posted by gearguts View Post
    After reading first post closer, it might be the same problem
    Try downloading the latest build from our website and see if you experience any issues after the update.
      Please install the test build (I've sent you a private message with the link) and see if that fixes the issue.
        Yes!!! The test build solves all the mapping issues!! Thank you!!!
          I'm having different problems with output from my triggers and back buttons:
          ex1) RT outputs nothing. LT only outputs if RT is held.
          ex2) In the rewasd binding UI, if I hit back right button on controller, it goes to the correct button in the UI. However, the binding gets output by the back left button instead of back right
            Edit: The website version worked, thanks!
