whenever i turn on rewasd all my connected bluetooth devices are disconneted, and after that bluetooth driver is turn off and dissapear from device manager.
my laptop : asus tuf a15
windows version 10 (tested with 21h2 and 21h1)
here is my bluetooth driver "Realtek Bluetooth Adapter"
i tested with both internal bluetooth from this laptop and orico bta 508 it give the same result
now i uninstalled rewasd and the problem has gone.
rewasd version: 610-5615
the problem is only happened in the past 2 week so i suspect only the new version conflict with my bluetooth, i will try the older version and tell about it later
update: after reinstall with older version 5.4 and 5.5.1 link:https://www.filehorse.com/download-rewasd/old-versions/
i dont see any error, bluetooth works flawlessly. Thanks
