Hello! ðŸ˜
I'm having a small problem combining 2 buttons on my xbox controller.
Let me first explain the situation,
The first button is the A button which in the game let's me slide my character into cover by tapping the button.
The second button is the Y button which let's me run when I hold the button in.
Is it possible to combine the Y into the A button so that when I tap A I can slide into cover and when I hold A I can run?
I hope that makes sense lol
(imma go to bed now lol but I'll reply to any messages tomorrow!)
Thanks in advance !! ðŸ˜
at the bottom right) -> Press time tab. There, you will be able to adjust the Long press time — the time you should press and hold the button until the mappings starts.
