Gyro to trigger shift layer?
  • Gyro to trigger shift layer?
    Is it possible to use the gyro on a ds4 to trigger a shift layer (without any keypress needed)? I.e. if I tilt (pitch) the controller up so it's pointing straight at ceiling, that does a mode shift, which is reversed when I tilt it back down to normal playing position. It seems like this should be possible with the current features in reWASDs gyro reupport, but I can't figure out how to set it up. Is this currently possible?
    No, it is currently impossible to change Shift layers with gyroscope. Though might be possible in the future. No details for now.
