Hi there!
So I have enabled autodetect associated apps to apply a certain config when a game launches. This is working fine. What I don't like is that even though the game process is running, changing the focus is changing the controller mapping back to default (which unplugs the virtual device and makes a sound).
The behaviour I'd like to see is that the auto-applied config stays enabled until I actually exit the game. In other words changing the focus shouldn't change the config.
Is there any way to achieve this?
Thanks in advance!
-- judges
Thanks in advance!
-- judges
at the bottom right) -> Tray agent tab and uncheck Remove applied config on exit from the associated app option there. This way, the config will be applied when you first open the game and will be there until you decide to apply another config manually or switch to another config using Autodetect.
