HELP: Since reWASD 6.1.0, combo shortcuts results in unwanted in-game activations
  • HELP: Since reWASD 6.1.0, combo shortcuts results in unwanted in-game activations
    Hi there,
    Firstly, I love reWASD.
    I use key combos activated by shortcuts, and have been using them flawlessly, until reWASD 6.1.0 has been released. Now when I activate the shortcut combo, the game still activates the in-game button mapped individual button presses. So when I press the reWASD key combo shortcut twice closely together, it activates the assigned key in game.
    Example: The shortcut trigger on my dual sense controller is Left-Dpad + PS button. This activates the combo, successfully, but, the game also activates Left-Dpad in-game, and when I then use that shortcut twice the game then performs an action associated with 2x Left-Dpad presses.
    This never happened before the release of reWASD 6.1.0.
    I'd greatly appreciate any help.
    Edit: I have reinstalled the previous version 6.0.1, and cannot replicate my issue! Solved! Won't be using 6.1.0 for a while, hopefully this can be fixed for a future update
    Please send me the config you are using. Right-click on the config's name to open the contextual menu and choose Open file location. I will need the correspondent *.rewasd file.
      I just updated my post. If you want I can still send you the config?
        I have tested, and the new 6.1.1 update has not fixed the issue that 6.1.0 caused.
          Yes, please send me the config. I assume I understand why it doesn't work, and it will require some manual config changes. But I need to see the file to be sure.
            Hello, I was about to make a post about exactly the same issue.
            Today I jumped from the version 5.8 to the 6.1 because I got a Flydigi controller, and I have a very hard time pulling my shortcuts since the individual button goes instead of the shurtcut.
            I link here the controller profile I am using.
            You can see as a reference that A+X normally does a macro, but the macro is actually almost impossible to do.
              We have confirmed the issue and are working on a fix.
              For now I suggest to use a temporary solution: have the buttons involved in a combo [Muted] and remapped to their virtual analogues just as I have done in the config attached.
                RL Dualsense.rewasd
                The extra quick chats are very important XD
                  mitchkdrose same solution applies to your case: have all buttons that are used in shortcuts muted and remapped to themselves.
                    There is also the same issue with the Shift mode, with the 6.1 version it seems that I have to press the shift key way earlier than I used to do with the 5.8 in order to not get the regular input, which is also pretty big inconvenience. I will be waiting with big hopes the hot-fix of this issue.
                      I am sorry for the delay.
                      Indeed, 6.1 version changed a lot, but there is a way to re-adjust your config so it works as it should. I am not sure what exactly has changed from your side. Could you please try it with my config attached and describe what exactly does not work as you expect?
