When i press the layer switch button, i expect the tayer to be applied immediately. But now, after update, the layer is applied with a delay.
I found that preference "Shortcut press time" affects the delay time. You can set this prefernce to maximum vaue and check.
Now i am forced to set this parameter to the minimum value. But this value is 50 ms. Please, fix this.
