Long press toggle remap doesn't work with triggers
  • Long press toggle remap doesn't work with triggers
    Hi. This has been happening for a good while, but the long press remap no longer works with the triggers.
    When I map a toggle by long pressing R2 or L2, the remap works like I mapped it with a single press instead. This doesn't happen with any other button, just the triggers,
      It happens with every config but here's the one I use the most
        We have fixed this issue in the new patch. Download the latest build of reWASD on the site and install. The problem should be solved after that.
          You sure? I clicked "check update" and it says the software is up to date (6.2.0)
            Yes, please update from the website manually. We have quickly re-released the fix which won't be send to those who have installed 6.2 version previously. The users who have previous versions, will get this build instead of the one that you already have now.
              Oh. Thanks a lot!
                It's fixed! Thanks a lot for the help! Have a great week.
                  Nice! Have a great week too
