Setting a combo to a two button press (PS4)
  • Setting a combo to a two button press (PS4)
    I'm trying to record a simple macro for the PS4 for Remote Play. It works great, except every single button on the controller for this particular game already has a function. Is there a way to assign the combo to say R2 and X (hold R2 and press X to launch combo), rather than just pressing X?
    I think you should try Shift mode. In Layer 0, set R2 as a Jump to Layer 1 and choose the Hold mode. In Layer 1, map your combo to X button. So, when you are holding R2, you will be jumping to Layer 1, where X button emulates combo. In Main configuration, X will work as is.
    I hope it will help!
      Awesome. I'll try that out. Thanks!
        Hold mode didn't work, but only because holding R1 or R2 in the game is used for other things and apparently when held disables all other actions. However, your suggestion got me to try toggle mode and that works great. Thanks again.
