First, the trackball update for the steam controller is amazing. I don’t know how you did it, but it’s actually smoother than the steam drivers!
With that being said, I’ve run into a problem. I want to have the gyro activate on touch of the right joypad. I set up a shift modifier and put the gyro as active on the first shift profile. It works as intended - when I put my finger on the right joypad to move the mouse the gyro activates. But when I flick my finger across to move the trackball and then lift my finger (which deactivates the shift profile) the cursor suddenly stops and will not continue with the trackball trajectory.
