I'm sure that this may be covered somewhere and would be more than happy to do the reading about how to setup this controller if someone would be kind enough to drop me a link that helps explain things.
In the meantime...
I am switching from a PS4 to a PC (Playing Warzone). On PS4, I was using a XIM adapter to run a mouse (right hand) and a PS3 Navigation Move (left hand). I stumbled across REWASD and really like what I see.
However, I'm afraid I am going to require a little help understanding the advanced controls setup as it pertains to the analog thumbstick on the PS3 Navigation controller. My goal is to attempt to get that thumbstick as close to an analog thumbstick as possible. Essentially, it needs to allow the character to move slowly when the thumbstick is only slightly moved, then full speed when the thumbstick is moved all the way in a given direction. I feel like this is possible in the advanced controls, but I'm not grasping the setup information.
Any help here would be awesome....thanks.
In the meantime...
