Slot Automatically Change from Slot 1 to Slot 2
  • Slot Automatically Change from Slot 1 to Slot 2
    My Xbox Elite Series 2 controller frequently changes to slot 2. There are no keyboard shortcuts defined for slots 2 thru 4. Slots 2 thru 4 are unchecked and do not have keyboard shortcuts defined. Please see screenshots.
    Any feedback or recommendations would be appreciated.
ID:	232684Click image for larger version
    Current slot can also be changed with the Profile button of your Xbox Elite Series 2 controller and is synced with the profile number that is set on the controller on every input from it (ex.: 1st slot - no lights, 4th slot - 3 lights on). Make sure to select 1st slot on the controller and avoid pressing the Profile button afterward.
    Since version 6.2.1 we have added an option to select the same slot that was selected before reWASD was closed. You can find the option in Preferences > Tray Agent.
      Thanks for the feedback.
