Hey,
bought the software yesterday and it's been working great :-).
Currently my "workflow" looks like this:
Pressing the XBOX-button (marked as hold and mute), triggers a series of other buttons being pressed.
Since hold is enabled, this series runs forever until i press the XBOX-button again. Exactly as I wanted it to work.
Problem: Sometimes I forget to disable the combination and go straight into the games menu, which results in happy clicking around and messing up my inventory.
Is there a way to set the menu button with another combination, which triggers the key as usual but also breaks all other holds currently engaged?
Thanks!
Thanks!
