is there a way to mute notification sounds ?
  • is there a way to mute notification sounds ?
    is there a way to mute notification sounds during profile switching ?
    reWASD does not use any sounds for notifications.
    I suppose you are talking about Windows sounds that play when a new device is connected or disconnected to a PC.
    You can mute the "System Sounds" with Windows Volume Mixer, or set "None" for these specific events at Control Panel > Sound > Sounds tab:
    • Device Connect
    • Device Disconnect
    • Device Failed to Connect
