Hi there, sorry for my english...
I'm starting to play Star wars Squadrons (spacecraft combat simulator if you don't know about it). In other flight games (as Elite dangerous) I can use the pedals of my G27 racing wheel for accelerating and brakeing at the same time that my Xbox360 controller for turning, shooting, etc...
The thing is, the game allows you to use controller and G27 pedals, BUT not at the strict same time. One input cancels the other, because the game switchs by blocks (keyboard/controller/racing wheel...) but it is unable to use them together. So I can speed up with the pedal and then (next) turn/rotate with my xbox controller or viceversa. But I can't accelerate/break WHILE rotating or viceversa, since one input overrides the other (I stop rotating when speeding up, or I stop speeding when rotating).
I'm acomplete mess if I have the accelerate/break option in a stick controller since my tendency is to use one stick for roll, another for yaw, but BOTH of them to pitch up and down. So everytime I do up/down movements I'm unintentionally accelerating and breaking.
SO, is it possible (If so I'd buy rewasd) to bind my g27 pedals to the xbox360 stick? Most of the apps I've tried (even my g27 has a profiler app) let you bind FROM a controller/pedal/racing wheel... TO a keyboard stroke, but not viceversa or not from a hardware (G27) to other (xbox360)
In reddit one user told me: "Look into using reWASD to bind both the controller and pedals to one virtual controller, then use that in Squadrons"
But is this possible? If I have understood correctly,, I must bind the controller to itself (in addition to pedals) since that "virtual" controller would be the same as the real controller I'm using, right?
Thanks in advance, and sorry for the long speech
