Unable to activate license
  • Unable to activate license
    Hi, unable to activate the license​ Click image for larger version
    This message appears when our app is unable to contact our server (secure.disc-soft.com) for license verification or is unable to communicate with our other processes.
    reWASD.exe and reWASDEngine.exe processes should have access to the Loopback Interface, the Local Network, and the Internet to work correctly.
    If you are using Windows Firewall, ensure all reWASD rules are enabled.
    If you use third-party antivirus or protection software, try adding all reWASD executables to the exclusions list.
      I'm having the same problem and I've already done what you're asking. I need help
        Do the following:
        - Uninstall reWASD with the "Remove my settings and activation info" option enabled.
        - Restart your PC.
        - Manually download and install these two packages: ASP.NET Core 8.0.4 Runtime and .NET 8.0.4 Desktop Runtime
        - Temporarily disable your firewall and anti-virus apps so they will not interfere with our installer.
        - Download and install the latest version of reWASD from our website or your personal account
        - Restart your PC again.
        - Run reWASD as Administrator.​
