When i click the installation file nothing pops up. Here is some info i collected from event viewer
1.Application: reWASD631-6778.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.TypeLoadException
at System.Windows.Automation.Peers.AutomationPeer.Ini tialize()
at System.Windows.Automation.Peers.AutomationPeer..cc tor()
Exception Info: System.TypeInitializationException
at System.Windows.Controls.ComboBox.OnSelectionChange d(System.Windows.Controls.SelectionChangedEventArg s)
at System.Windows.Controls.Primitives.Selector.Invoke SelectionChanged(System.Collections.Generic.List`1 <ItemInfo>, System.Collections.Generic.List`1<ItemInfo>)
at System.Windows.Controls.Primitives.Selector+Select ionChanger.End()
at System.Windows.Controls.Primitives.Selector+Select ionChanger.SelectJustThisItem(ItemInfo, Boolean)
at System.Windows.Controls.Primitives.Selector.OnSele ctedItemChanged(System.Windows.DependencyObject, System.Windows.DependencyPropertyChangedEventArgs)
at System.Windows.DependencyObject.OnPropertyChanged( System.Windows.DependencyPropertyChangedEventArgs)
at System.Windows.FrameworkElement.OnPropertyChanged( System.Windows.DependencyPropertyChangedEventArgs)
at System.Windows.DependencyObject.NotifyPropertyChan ge(System.Windows.DependencyPropertyChangedEventAr gs)
at System.Windows.DependencyObject.UpdateEffectiveVal ue(System.Windows.EntryIndex, System.Windows.DependencyProperty, System.Windows.PropertyMetadata, System.Windows.EffectiveValueEntry, System.Windows.EffectiveValueEntry ByRef, Boolean, Boolean, System.Windows.OperationType)
at System.Windows.DependencyObject.InvalidateProperty (System.Windows.DependencyProperty, Boolean)
at System.Windows.Data.BindingExpressionBase.Invalida te(Boolean)
at System.Windows.Data.BindingExpression.TransferValu e(System.Object, Boolean)
at System.Windows.Data.BindingExpression.Activate(Sys tem.Object)
at System.Windows.Data.BindingExpression.AttachToCont ext(AttachAttempt)
at System.Windows.Data.BindingExpression.MS.Internal. Data.IDataBindEngineClient.AttachToContext(Boolean )
at MS.Internal.Data.DataBindEngine+Task.Run(Boolean)
at MS.Internal.Data.DataBindEngine.Run(System.Object)
at MS.Internal.Data.DataBindEngine.OnLayoutUpdated(Sy stem.Object, System.EventArgs)
at System.Windows.ContextLayoutManager.fireLayoutUpda teEvent()
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.UIElement.UpdateLayout()
at System.Windows.Interop.HwndSource.SetLayoutSize()
at System.Windows.Interop.HwndSource.set_RootVisualIn ternal(System.Windows.Media.Visual)
at System.Windows.Interop.HwndSource.set_RootVisual(S ystem.Windows.Media.Visual)
at System.Windows.Window.SetRootVisual()
at System.Windows.Window.SetRootVisualAndUpdateSTC()
at System.Windows.Window.SetupInitialState(Double, Double, Double, Double)
at System.Windows.Window.CreateSourceWindow(Boolean)
at System.Windows.Window.CreateSourceWindowDuringShow ()
at System.Windows.Window.SafeCreateWindowDuringShow()
at System.Windows.Window.ShowHelper(System.Object)
at System.Windows.Window.Show()
at System.Windows.Window.ShowDialog()
at RewasdWpfInstaller.App.OnStartup(System.Windows.St artupEventArgs)
at System.Windows.Application.<.ctor>b__1_0(System.Ob ject)
at System.Windows.Threading.ExceptionWrapper.Internal RealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatch When(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.DispatcherOperation.Invok eImpl()
at System.Windows.Threading.DispatcherOperation.Invok eInSecurityContext(System.Object)
at MS.Internal.CulturePreservingExecutionContext.Call backWrapper(System.Object)
at System.Threading.ExecutionContext.RunInternal(Syst em.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threa ding.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threa ding.ExecutionContext, System.Threading.ContextCallback, System.Object)
at MS.Internal.CulturePreservingExecutionContext.Run( MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Threading.DispatcherOperation.Invok e()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(In tPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation( System.Object)
at System.Windows.Threading.Dispatcher.LegacyInvokeIm pl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(Syste m.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl( System.Windows.Threading.DispatcherFrame)
at System.Windows.Threading.Dispatcher.PushFrame(Syst em.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Ob ject)
at System.Windows.Application.RunInternal(System.Wind ows.Window)
at System.Windows.Application.Run(System.Windows.Wind ow)
at RewasdWpfInstaller.App.Main()
​2.
Faulting application name: reWASD631-6778.exe, version: 6.3.1.6778, time stamp: 0x63342bc4
Faulting module name: KERNELBASE.dll, version: 10.0.19041.572, time stamp: 0x979ddb1d
Exception code: 0xe0434352
Fault offset: 0x00129ab2
Faulting process id: 0x388
Faulting application start time: 0x01d8e3a3078be969
Faulting application path: C:\Users\Joe\Downloads\reWASD631-6778.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: e4fc28b6-a76a-4afc-a56a-36ae3420852e
Faulting package full name:
Faulting package-relative application ID:​
Im on windows version 20H2
​2.
