Limit max stick input?
  • Limit max stick input?
    Is there a way to set a maximum input for the thumpsticks?
    e.g. moving the stick to max, but it only recognizes 50% movement.
    I only found a way to edit deadzones.
    This can be done with a response curve. Try to set it as in the screenshot.
      Works perfect.
      Thank you
