Question about reWASD
  • Question about reWASD
    Hello there!
    How can I disable the A and D keys when I press a click?
    Thank you!
    I need the correspondent *.rewasd file.​
      This is my configuration. If you could me help me I'd be very grateful!
        What I want to do is when I hold down the click, the keys A and D are disabled and when I release the click, the keys are enabled again.
          It's not entirely clear which click you mean.
          However, I can explain the principle.
          You need to assign to your "click" jump to another Shift layer (e.g. Shift 1) in Hold mode.
          Then in layer Shift 1 apply Mute to the A and D buttons of the keyboard.
          Thus, you will achieve the desired result.​
            Thanks a bunch!!! It worked
              We are always happy to help!
