Hi all,
I can't seem to figure out how to do the following combo without creating a combo manually with 102 key presses
press A 100 times followed by X 2 times
The solution should be easily modifiable so that if I want "press A 349 times followed by X 3 times" I should just change two numbers
I know there is the iterations feature, but that just repeats the entire combo N times. Am I missing something?
Note: New to REWASD. Bought it hoping it might replace my current setup (which works wonderfully) of DS4Windows + JoyToKey + Autohotkey
