Any way to have the Victrix Gambit recognized as Elite series 2?
  • Any way to have the Victrix Gambit recognized as Elite series 2?
    The Victrix Gambit is recognized as a Xbox Series S|X controller. Which means that afaik, I cannot use the paddles to create different profiles? Very new here so let me know if I'm mistaking lol.
    At the moment, only the rear paddles of the Xbox Elite 1, Xbox Elite 2 and Flydigi controllers can be directly remapped in reWASD, because they are reported to the Windows system as separate controls.
    At the same time, a workaround has recently appeared that can help in remapping additional buttons of other controllers using their native software. We cannot guarantee success, but you can try this method.
      Thanks for your answer. I actually have a Flydigi Apex 3 controller on the way.
      Should this one be recognized with paddles? (Or that only applies to Apex 2/Razer)
        We want to fully support the Apex 3 (including paddles), but in order to do so, we need to get to know the device better.
        So far, they cannot give you an approximate date.
        Stay tuned!​
          Got it, thank you
