Need help mapping mouse for Apex in a way that allows AA & Shield Swapping..
  • Need help mapping mouse for Apex in a way that allows AA & Shield Swapping..
    So I was working on a config for Apex that lets me use PC controller aim assist with my mouse while firing, and I got it to work great, but the only problem is I can't shield swap because the mouse doesn't have it's normal function. Anyone have any ideas on how to rebind the shield swap/menu interaction Left Click standard to something else, or how to apply a single button on/off hotkey for REwasd, or a way to get them both functioning simultaneously?
    Hello! I'm afraid I don't quite understand what you want to do.
      I figured it out I just needed functionality of both the mouse and the controller at the same time.
