i was wondering if you guys could implement a button that would invert the gyro when pressed or a button that would switch configs when pressed so that i can switch to another config that has the gyro inverted with a button press and then switch back to the original by pressing the same button i would do this with shift layers but you can't change the settings for each individual layer.
Udate: sorry didn't realize that i can actually use shift mode and just bind moving the gyro to the left as moving the mouse to the rite and vice versa for the left, for some reason when i saw the "invert x axis" mapping in the advanced options of gyro i just assumed it was the only way to invert the x axis.
