Keyboard being recognizes as mouse and keyboard
  • Keyboard being recognizes as mouse and keyboard
    My k70 corsair is being recognizes as keyboard and mouse. So i cant use my mouse to emulate the directions. Only the buttons work (ex: to aim or to fire).
    Can someone help?
    To fix it, please follow these steps:
    2. Use Detection mode to find the correct Keyboard and Mouse. If you press the mouse button but see the keyboard in reWASD, then you will need to re-initialize it (from the contextual menu of an active device): https://help.rewasd.com/interface/device-detection.html
    3. After you are sure about all the devices, please group Mouse and Keyboard and try to Apply your config and test it in joy.cpl or in a game​
      I've tried, but the reWASD still recognizing the keyboard as keyboard + mouse (even the icon on the bottom left corner shows it). =((
      I make a test with another keyboard, but the problem still remain.
      is it possible because i running the trial version?
        We have to make it clear that your keyboard is not recognized as a keyboard and mouse, but identifies as a composite device with functions of both a keyboard and a mouse.
        If you want to remap it as a keyboard, you are required to initialize it as one according to the instruction strokel provided above. The resulting group should look like this (pay attention to the icons):
        Note: the Trial Period is not related to this case in any way.
          I followed all the instructions and the problem was still there. Maybe the mapping i was trying to use had some blocked configs by the trial version. I dont know what was wrong.
          But now i got the license and its working well.
          So problem solved!
          Anyway ty guys for the support!
            Click image for larger version  Name:	2023-01-18_2-34-01.png Views:	85 Size:	3.8 KB ID:	235246
            Hes talking about this icon Click image for larger version
ID:	236215​which pops up without a group, so its a device for itself.
              This icon suggests that this device has features of both keyboard and mouse and is currently initialized as a keyboard. If it is a mouse and you want to remap it as one, you have to [Re-initialize] it as a mouse.
