unverified license
  • unverified license
    today im buy more pack but i cant "failed to connect to server" so i try clean uninstall now my REwasd cant use with message "unverified license" and fail check your network connection
    "Unverified License" error is shown when reWASD GUI (reWASD.exe) is for some reason unable to communicate with either our service (reWASDService.exe, Game Controller Mapping Service) or our Engine process (reWASDEngine.exe).
    Please make sure all mentioned processes and services are running and not blocked from access to the Lookback Interface (127.0.0.1), Local Network, and the Internet.
    To avoid 3rd party interference, allow Internet access for all three in your Firewall software and add them to exclusions in your Anti-Virus/Protection software.
    If none of our suggestions would help, try to do a clean reinstall of the reWASD app:
    1. Back up your profiles from c:\Users\Public\Documents\reWASD\Profiles\ folder.
    2. Uninstall reWASD with the "Remove all" option.
    3. Restart your PC.
    4. Download the latest version of reWASD from our site.
    5. Add the installer to the exclusions list of your Anti-Virus/Protection software.
    6. Install reWASD.
    7. Restart your PC again.
    8. Import your backed-up configs.
      im try clean reinstall with turn all of antivirus and 3rdparty but still cant connect server
        how to fix 2time clean uninstall
          There is something on your PC that is blocking access to our service. Unfortunately, we cannot determine on our end which application on your PC is doing this.
          If you are using Windows Firewall, ensure all reWASD rules are enabled for all network types.
          If you use third-party anti-virus or protection software, try adding all reWASD executables to the exclusions or trusted apps list.
          If you use an Eero Security service on your router, please allow the secure.disc-soft.com domain in its settings or disable the service.
          If your PC cannot make a stable connection to our server, we suggest using a VPN service or contacting your Internet provider for further assistance.​
