Hello guys, does rewasd support dualsense speaker audio like Dualsense X app does? I am unable to find this option...thank you in advance.
Dualsense speaker audio not working.
 Games won't be able to provide DualSense specific haptic feedback or use adaptive triggers if you are remapping your DualSense to a virtual controller that doesn't support these features.
 This won't be an issue once we are able to emulate a DualSense controller or send inputs as if from the controller itself (both features are currently at planning stage).
 We do have some presets for Adaptive Triggers of DualSense controller though. You can read more about them here.
 Connect your Dualsense controller to your PlayStation 5 console using a USB cable and go to "Settings" > "Accessories" > "Controllers" > "General" > "Controller Information" > "Update Controller". If there is an update available, follow the prompts to update your controller firmware.Originally Posted by hamletiano View Postgeometry dash lite
 If your DualSense speaker sound doesn't work, try to verify the PS5 audio settings to make sure that controller speaker output is turned on. Also, ensure that the controller firmware is current. If that fails, resetting the controller or trying it on a different console can isolate the problem.speaker cleanerLast edited by james35; 20.05.2025, 15:08.
