Hello, can someone give me an anti recoil for MW2 for a physical mouse? I have downloaded some configs but there seems to be no difference with the recoils. thanks
Anti-Recoil
This is possible to create an anti-recoil combo only in case you emulate a virtual stick on your mouse. If downloaded configs are not suitable for you, the best way is to create your own. You can check out cases #20 and #19 here to create no recoil combo: https://help.rewasd.com/faq/usecases.html#20​
