The new high performance mode that comes with 6.5, I am assuming this is a boost to the polling rate of the virtual controller, or is it something else? How much of a boost, I'm curious?
High Performance Mode
You are right. Currently it increases rate from 250 Hz (4 ms) to 500 Hz (2 ms). But these are details of internal implementation and may be changed if needed later.
Note that on virtual DS4 actual report rate(for games) is still 4 ms, because we have to match real controller. But it still has effect because your latency for key presses is less.
But on virtual Xbox One/360 we are not limited to 4 ms and this has more direct effect. In fact, virtual Xbox One is the fastest from all virtual gamepads and is recommended if you need minimal latency.
Spanish Ty RibShark ibmpork
We are pleased to announce that reWASD 9.0.0 update has been released, which now allows you to set the Virtual Device Performance value to ultra, which is 1000hz. Hurry up to update!
