I have the Razerine Wolverine V2 and downloaded the rewasd trial. Before buying it, I wanted to ask two questions.
1. Does rewasd work with this controller? I read somewhere that it is treated like the xbox elite series 2 in the software, but when I use it, I can only change the base keys, not the extra buttons (M1-M6, like the paddles on the back)?
2. I would like to use this software to play with my controller on FF14. But I would like to use the controller buttons (XYAB) as normal, and then when I press Left Trigger or Right Trigger, I want to then have the d-pad and XYAB buttons become keyboard mappings (like 0-9) so I can use macros on these shift-buttons to cast abilities set on hotbars in the game. The game itself is being run in gamepad mode. Any way to do this?
I am running the game in gamepad mode because I only use the controller when playing, so playing in the M+KB mode would make it difficult to open menus and what not. But I want the ability to use macros, which is not possible using only gamepad buttons since there aren't enough of them.
Thanks!
Thanks!
