Issue setting up virtual controller by default
  • Issue setting up virtual controller by default
    I'm trying to use reWASD as a way to default my dualsense controller to XInput. I've looked and I can't see a way to do this without setting it up with every exe file I want to use it with. Am I missing something?
    I'm afraid I don't fully understand what you want to achieve with reWASD. What do you mean by default?
      In all situations, I want reWASD to have a virtual controller that is XInput, and for the dualsense controller to be otherwise ignored.
        In your case, you need to choose the virtual controller and click on apply. reWASD will create a virtual controller upper your physical one and hide it
