I'm attempting to use the Azeron Cyro with the latest version of reWASD. When I use the joystick, the buttons I have mapped to the joystick rapidly fire and are often not correctly detected (e.g. pressing right will cause Down to rapidly trigger instead). This is not happening when using Azeron's software, so I don't believe its a problem with the device. The Cyro using the latest firmware.
Is this a known issue?
