So I'm using a config which allows me to switch inputs between:
1. Mnk (where my controller acts as the keyboard)
2. Controller only
I do this using the toggle shift feature which is assigned to a foot pedal which is interpreted by rewasd as a keyboard. I use it fairly infrequently. I'll often go a whole game without switching inputs.
Now, the problem is when its been a long time since using toggle shift, such as 10 minutes, the game will tab out as I press the foot pedal a.k.a toggle shift. This problem never happens if I press it after <3 minutes of having not pressed it. It's something to do with the amount of time passed since the last press. I tried switching inputs in the game without using rewasd and that works fine so its definitely a Rewasd issue.
tried turning off overlay
tried muting toggle shift button
Any help would be greatly appreciated.
2. Controller only
