For an example, is it possible from going from shift layer 1 back to main layer 1 using a specific key. So in shift layer 1 that certain key switches back to main layer, but in main layer that same key has a different function?
Switching shift layers
The key you assign to change the Shift layer will only be responsible for changing the Shift layer.
You can learn more about Shift mode in this article. ​
