Quickest controller
  • Quickest controller
    Hi, Is there such thing as the quickest response time controller? Or are all controller types the same since we can edit with them on rewasd e.g. (rapid fire, instant quick press)
    Just asking as I am looking for a new controller.
    When using reWASD, the response time on all controllers will be approximately the same.
    However, if you want to purchase a controller for use with reWASD, we may advise you to select one based on the list of supported devices.
      Great, thank you
