Do I have to clear all control bindings in SC for reWASD to work or is SC not compatible with it currently?
Need some help with controller conflict between SC and reWASD
There is no need to clear any bindings in Star Citizen for reWASD to work with it.
Just make sure whatever you remap your controls to matches the bindings you have set in the game.
If you are using reWASD for the first time, we suggest checking this article first.
You can use configs from our Community page as an example.
