I have an external numpad that I use as a macropad for games. I would like it to perform the same functions across different games / applications, e.g. Numpad1 = F13.
Is there a better way to do this or do I have to create the same layer with the same configuration in all profiles I use?
→ Tray agent and make sure the option Remove applied config from slot on exit from the associated app is enabled.​
