Ps5 controller won’t connect any more
  • #16
    You can post the .nfo file here or send it to me.
    • #17
      .nfo file.....
      https://file.io/b8lTtRExH3OJ​
      • #18
        Your system has a third-party driver for virtual device emulation, which may interfere with the normal operation of the reWASD config.
        This is the vigembus component.
        You can use this tool to remove the vigembus.inf component.​
        • #19
          Thanks! Will try. Everything is working right now after fresh install with all settings deleted too.
          • #20
            Just an update I still have problems with this. Lately reWasd was failing to see even my keyboard and mouse using the detect active divices button. I cleared data in the settings preference page and the controller connected and reWasd started detecting my devices once again. Not sure how long it will last but that’s faster than reinstalling reWasd.
            • #21
              Let us know if the problem reappears. In that case, we will look into the problem in more detail.
