Are Dualsense edge's back paddles programmable?
  • Are Dualsense edge's back paddles programmable?
    I wonder if the back paddles of dualsense edge can be programmed (combo) like other original Dualsense buttons?
    Anyone?
    Sure, you can assign a combo to the back paddles.
    However, please note that the DualSense Edge must be connected to a PS5 in order to use the Fn + X, O, Triangle, Square buttons with reWASD.
    When connecting the gamepad to the PS5, it is important to initialize the default profile for correct use.
    More information can be found by following the link.
      Oh okay thanks!
