It would be appreciated if you could answer what option has the effect of continuing to press X -> A -> LB in this order, rather than repeatedly hitting A on the elite pad.
I need help with the options of using the Elite pad.
For example, if I keep pressing the A button, I want to have the effect of continuing to press X -> A -> LB in the order.
And I want the effect to stop when I release the A button. Also, if I press and hold the A button again, I want a function that repeats X -> A -> LB, X -> A -> LB repeatedly.
I respectfully ask for your help.​
You should probably check the [Combo] feature along with the [Turbo] function of the [Rapid Fire] feature.
Note: [Advanced Mapping] feature would also be needed for this to work.
