Notification message that was not there previously
  • Notification message that was not there previously
    Every time I turn on my computer now, as soon as Windows loads, I get a REWASD notification saying that "Switch Pro controller is disconnected, or "Xbox Elite is disconnected".
    I only ever used to see those when I would turn a controller off after finishing a play session. Or if I tried to load a profile that used a controller that wasn't connected(maybe), but it definitely never used to say that when I just started Windows, and hadn't yet even connected any controllers.
    Is there a setting or something I need to change to switch it back to the way it was before? Could this be a bug maybe?
    Thanks for any help
    Hi. Could you please send us a screenshot or video showing your issue?
      This is the type of message that pops up. Again this is after a fresh boot and no controllers plugged in.
        This notification appears when applying a config at the start of your OS when one of your controllers in the group to which the config is applied is disconnected.
        You can turn off config auto-apply at system startup and when reWASD is launched in Preferences in the "Tray agent" section.​
          That did the trick. Thank you, strokel!
            You're welcome!
            We are always glad to help you.
