I've been using a DS Edge on a Windows 10 PC to great success, using a profile that sets the touchpad to a mouse. Works great.
Today I'm trying the same controller plugged into my new Win 11 gaming laptop. When I try any profile with the mouse function turned on, the moment I enable the profile the screen cursor starts jittering. If I then touch the touchpad, it jerks all over the place in an almost square-like pattern, and even just slight movements of my finger send it all over the place, gradually moving in a chaotic square-like pattern up to the northwest corner of the screen.
I've tried a totally blank profile, with no mappings other than setting "Analog -> Mouse" to the touchpad. The moment it's enabled, it just goes wild again. Unplug and connect to the other machine, works without issue. Back to the laptop, try again, crazy jitters.
Weird thing is that I was seeing similar behaviour on this computer in Steam, with ReWASD close, if I left the mouse emulation enabled in its Desktop Configuration. It feels almost as if there is something Win11-related interfering, possibly a bad driver. The controller shows as "DualSense Edge Wireless Controller" in Windows, same as on the Win 10 PC. Anyway, I've got steam closed and all other possible controller tools I can find have been completely uninstalled. If anyone has tips on other things to check, I'm open to suggestions. Thanks!
