Warzone 2 unsupported hardware device notification
  • Warzone 2 unsupported hardware device notification
    Like the tittle says, today I got a notification in-game. I have been using rewasd for almost 2 years with no problems until now. I can play, I have not been banned, but I got that notification and I'm afraid of using it. Does anyone know anything about this?
    If the config you are using relies on macro commands, I'd suggest removing them. Otherwise, you should contact the game`s support team for assistance.
      ohh ok, I did tried the rapid fire funtion. So is off now and I will be safe? right?
        Unfortunately, I have no idea how macro detection works in this game, so I can't guarantee anything. But removing Turbo/Toggle mapping from the config is the minimum you should do.
