Been using Vortex config for months. Loaded up REWASD and it will load, but hitting home no longer deactivated REWASD, I have to hit CTRL-ALT-DEL which switch REWASD off completely. I have rebooted, reloaded the configs, my hardware is the same, no changes made since yesterday where it worked. Any ideas?
Home button stopped working
The config is completely good, and the Home button is adjusted correctly.
If it doesn't work in your case, it means that your keyboard and mouse were initialized wrong or you added a wrong device to the group.
Please do the following:
Use the [Clear data] button at [
> General]. Enable the [
Device detection mode] to find a needed mouse and keyboard
https://help.rewasd.com/interface/device-detection.
html https://help.rewasd.com/faq/troubleshooting.html#24
Please note that this is an essential thing. I mean creating a group with your Mouse and Keyboard and the devices should be recognized correctly as well​
