reWASDService.exe running in background
  • reWASDService.exe running in background
    Hello.
    How do I stop the service from running when windows starts. I only want the service to run when i use the program.
    I have just been ShadowBanned from MW2 and Warzone 2. My first ever shadowban. I am not saying its from this service running. But it could be,
    And the fact Activision give no details on what caused the ban, I and paranoid now.
    This service does not need to be running when I am not using ReWASD.
    Is there anyway to do this?
    [reWASDEngine.exe] is the Tray Agent process, not the service. You can shut it down by using the [Exit] command in the agent`s tray icon context menu.
    You can stop the service (reWASDService.exe) via Windows Services.
      Thanks for the reply.
      I know i can manually stop the service.
      But I am asking how can I stop the service from starting with windows.
      I do not want to manually stop the service every time I boot up windows. Surely there is a way to do this?
        You could try changing its start type to [Manual].
          Yes I finally found it.
          Its called "Game Controller Mapping Service" in the services window. But everywhere else in task manager its called " reWASDService.exe"
          was stumped trying to locate it in the actual services window.
          ‚Äč
          I set it to manual. sorted.
          Thanks again...
