PSremote not work
Please check if the [Use with PS4 Remote Play] option is enabled at [Virtual controller settings].
The [Create virtual devices under physical hub] option at [Preferences > Input devices] must also be enabled.
If it already is, turn it off, click [Apply], restart your PC if asked, and turn the option back on.
Wow, thx to your help.Originally Posted by Shion View PostPlease check if the [Use with PS4 Remote Play] option is enabled at [Virtual controller settings].
