Power A Fusion Pro 2
  • Power A Fusion Pro 2
    Can reWASD support this unit and will it allow the 4 x rear paddles to be remapped instead of them just following main keys etc.
    Thanks
    Unfortunately, reWASD is not able to detect the additional buttons/paddles, since they are not reported to Windows as separate controls, unlike Xbox Elite 1 and 2 paddles.
      Thanks for the answer so to confirm if I purchased a Elite 1 or 2 reWASD will detect the rear paddles so they can set as independent buttons and would this then work through steam and steams big picture mode or just play the game through steam with reWASD running also would I be able to just use the basic download of reWASD or would I need some of the add on,s to reWASD.
        1. If you turn off controller support in Steam settings and use only reWASD remapping, then there should be no issues.
        2. It all depends on what mappings you plan to use.
        You can find a complete description of the basic and additional functionality in this article.​
