RECONFIGURE LEFT ANALOG STICK - NEED HELP PLEASE SOMEONE
  • RECONFIGURE LEFT ANALOG STICK - NEED HELP PLEASE SOMEONE
    I really hope someone can help me.
    Is there a way to reconfigure the left analog stick to not be recognized as a directional input, but solely be recognized as individual buttons for each direction?
    I could really use the help. Thank you.
    Hello.
    If you want the stick to still remain a left stick, but not play diagonal input and work strictly up, down, left and right, then you need to go to Advanced stick settings and enable the use 8 digital directions option (1).
    If you want to map something to the diagonal, you can select the diagonal direction from the "direction" dropdown (2) and create the mapping you want.
