Finish combo when keyup with turbo
  • Finish combo when keyup with turbo
    Is there a way to configure it so that if a key has a combo and turbo enabled, on keyup, if the combo is still executing, it should finish the remaining steps.
    Example:
    Remap A to a combo that presses "Q, W, E, R, T, Y" and turbo enabled. If you release A fast enough, it sometimes only types the first few characters. It's easier to reproduce with delays in the combo.
    Is there any way to make sure the combo finishes even if key was released early?
    [Turbo] flag makes the [Combo] repeat until the button is released. And when it is, the [Combo] will stop at that exact moment. There is no option to "finish the Combo" in reWASD with these parameters.
