Finally pulled the trigger on DualSense ... could have gotten so many games on Steam for that lol ... but its worth it compared to what I had before
Try to remap DS touchpad to mouse ... everything feels natural ... except tap mapping
Feels unnatural:
* if map mouse click to Single Press ... if i touch touchpad to move mouse ... ReWASD registers it as I hold mouse, then release mouse when i finish moving (in effect holding mouse button while moving mouse - dragging mouse)
* if i do it as combo with execute at once ... once i touch touchpad - it registers as mouse click ... also not good - if cursor over button and i want to move mouse away ... simply touching touchpad maps as mouse click
* other options dont improve much too
In my opinion ... once tap is identified (finger make contact and immediately releases) ... ReWASD should register it as tap - no mouse movement should be applied (otherwise cursor can wonder around and miss click point).
If its not a tap ... then movement of finger can be interpreted as mouse movement.
I believe this is how touchpad on computer worked ... if i remember correctly, on PC to achieve dragging - you needed to click touchpad, hold it in click position and move your finger (which can be done on REWASD now easily)
I reread the post ... and even to me its a bit confusing ... but atm, I cannot think of better way to put it ... hopefully, you will get what i mean
Feels unnatural:
